Dmitry_Mezenin
Trackpad, MacOS: Palette and sliders issue
  • November 22, 2023
  • 4 replies
  • 527 views
Recently (after a Figma or MacOS update, can’t say for sure) Trackpad started working strangely. If I do Drag outside the sliders (or color paletter) and then go back, UI thinks I have still pressed trackpad and moves the position of picker. This is annoying. Previously when dragging the cursor outside the slider (or palette) this didn’t happen and you had to click to select a position again.
https://youtu.be/HzSpMJmqdcs — screen record.
p.s. I have a Magic Trackpad 3 with a Macbook Air M2 and the exact same problem on another Macbook Air M1 on the built-in trackpad.
    Best answer by Ryan_52
    Hi everyone, thank you for reporting this. We are pleased to inform you that the fix has been successfully released!
    Please refresh Figma to ensure that you are using the fixed version.
    Hey Dimtry,
    Thanks for flagging this. We are not aware of this issue, would you mind reaching out directly to the support team with your screen record by filling a form here? : https://help.figma.com/hc/en-us/requests/new They can investigate it further. Thank you!
    December 7, 2023
    I’m having the same exact issue! And it only started happening recently. It makes it hard to select any grey tints that run along the edge of the color picker box. Any solutions?
    Hi everyone,
    After checking internally, I confirm this is a bug. I’ve flagged to our team, our engineering team are still investigating this issue - while I cannot set an ETA yet for the fix at this time. Thanks for your patience in the meantime!
    Ryan_52
    Ryan_52Answer
    Technical Quality Specialist
    January 10, 2024
