Jul 25, 2024 1:48 PM UTC
This document contains unsaved changes. These changes are saved locally and will sync when Figma reconnects.
I added an image to a file, and the following error message appeared:
“Error: This document contains unsaved changes. These changes are saved locally and will sync when Figma reconnects.”
ksn
Jul 25, 2024 3:45 PM UTC
@vivek8 definitely not expected – first, did the image successfully add itself to the file, or did this error pop up and the image actually was inserted as expected?
Are you still getting the unsaved error message consistently, even after closing + restarting Figma?
Additionally, can you try some things to see if this is file-specific?
Try duplicating the file you’re working on > then adding the image. Does that seem to work, or do you still get the same unsaved changes error?
