flo_che
Mar 7, 2024 9:24 AM UTC
Theme switch with variables
Hello, here is my problem:
I have 2 themes (A and B) for a button with icon and label text.
Depending on the chosen theme, the button automatically displays the A or B icon variant by using variables.
It works very well, except that if I apply an override color on the icon of theme A, this color resets if I apply theme B.
I would like this color to be preserved when I change themes.
Anyone have a solution for this?
Figma link here
Jan-Willem_van_Veelen
Jun 24, 2024 7:20 AM UTC
Thanks @Nate_G for the suggestion. I tried this set-up, but it seems that after Figma changes the icon-version, it does not apply the icon-color variable. Maybe applying the variables happens in the wrong order, so first color change, then icon-variant (that is then in it’s default color). I’ll keep digging into it and will let you know if/when I figure out a solution.
V_Verena
Sep 16, 2024 12:13 PM UTC
We currently have the same problem for our design system. Have you perhaps found a solution for this?
flo_che
flo_cheAuthor
Sep 16, 2024 3:58 PM UTC
Hello @V_Verena, unfortunately no, i didn’t found a solution for rhe moment. 😔
Dieter
Sep 17, 2024 10:11 AM UTC
Hi,
I am experiencing the same issue with our icon library. Some colour overwrites got ignored when another mode is applied. I created a file to illustrate our issue, where you can play around.
Figma color variable overwrite got ignored when changing modes.fig (94.1 KB)
ksn
Sep 18, 2024 5:00 PM UTC
Hey everyone - from what I understand on my end, these need to be reviewed by our support team on an individual basis. Apologies that I can’t assist further at this time.
I’d recommend anyone who is having issue with these inconsistencies file a ticket here: https://help.figma.com/hc/en-us/requests/new?ticket_form_id=360001744374
Dan_Flynn
Oct 2, 2024 7:32 PM UTC
I’m also having this issue, where, when you move a component from Theme A frame to Theme B frame, something such as a nested button component will revert to default state and doesn’t maintain any overrides (e.g. label text, rounded corners)
