Nadia145
Aug 3, 2025 1:19 PM UTC
The plugins didn't show up when searched
Hi, sorry for my English, I'm not a native speaker.
I have a problem with plugins, when I try to open specific one from library or find one searching, it didn't loads  from library and don't finds up when searching inside the file (when I try to search in manage plugins), did someone else face this problems? How did you find a solution?
Aug 4, 2025 2:23 AM UTC
Hi ​@Nadia145,
No worries, your English is totally understandable!
I understand you're having trouble searching for or opening a specific plugin.
To help troubleshoot, could you let us know:
  • Which  product you're using (Design, FigJam, or Dev Mode)?
  • Do you have edit access to the file where you're trying to use the plugin?
  • Are you unable to search for a specific plugin, or are no plugins showing up at all?
If you’re working in a Figma Design file and have edit access, try this:
  1. Click "Actions" in the toolbar
  2. Go to the "Plugins & widgets" tab
    There, you should be able to see your recently used plugins or search for new ones from the Community.
You can find more details here: Use plugins in files
If the issue continues, would you be able to share a short screen recording or some screenshots showing what you're experiencing? That will help us better understand the issue and find the best way to help.
Thanks!
