Taeyoon_Lee
Jun 7, 2024 12:38 PM UTC
The instance swap component of the variant, which allows the property to be automatically changed through a variable, always resets when the variable mode is changed
The instance swap component of the variant, which allows the property to be automatically changed through a variable, always resets when the variable mode is changed.
  1. Change text(B) to C which is “Base Component 2” inside“Problem Component”
  2. Select “Problem Occurs” section, And change “Variant” mode to “Mode 2”
  3. All layer name of “Problem Component” children has been reseted And override has been reseted.
Figma Reproduce
Jun 11, 2024 9:18 AM UTC
Hello @Taeyoon_Lee, Thank you for bringing this to our attention and for sharing your design file with us.
I’ve reached out to our internal team for further consultation. I’ll let you know once I got any update.
Meanwhile, if anyone in our community has any insights or suggestions, please share them here.
Thanks again!
Yara_Farhat3
Feb 17, 2025 7:39 PM UTC
hello, what was the solution here.
I have English and arabic variants of a  component using a slot, there is an instance swap on the slot.
the switching is not working properly.
