The image inside the Rectangle is inserted with a highlight.
If you insert an image into a Rectangle, its background becomes highlighted, but if you simply drag and drop the image into the project, it inserts normally. What could be the reason for this?
Lightshot
Hi there, thanks for reaching out. I tried to reproduce the behavior but unfortunately I couldn’t. Would you be able to share the screen recording so we can follow the steps you’ve taken? Thanks!
