Pradyumna1
Aug 29, 2024 5:43 AM UTC
The applied variable appeared with a strikethrough
Hey Junko,
Would you explain why this is happening. I’m connecting the Boolean variable to a Boolean instance, but why this strike showing in it. See the image below.
Screenshot 2024-08-29 110516
Pradyumna1
Aug 29, 2024 8:55 AM UTC
@Junko3 please help me in this.
Sep 2, 2024 9:11 AM UTC
Hi @Pradyumna1, Thank you for bringing this to our attention! I’ve created a new post here to address your question.
I’m assuming your concern from the attached screenshot, but are you asking why the applied variable appeared with a strikethrough, correct?
I’m not completely certain, but it seems that you applied a boolean variable to a variant properties in an instance.
If this is the case, could you please verify if you have set one variant’s value to “True” and the other to “False”?
On my end, when the variant property value is not set as mentioned above, the boolean applied to that variant property appeared with a strikethrough.
You can learn more from the following resources:
I hope this information helps. If I missed anything, kindly let us know. If anyone from our community has additional insights, feel free to contribute.
Thanks again for reaching out!
