Viktoria_Kalashnyk
Feb 3, 2021 8:40 PM UTC
Text goes away when applying Auto Layout
I tried to apply Auto Layout to rectangle with text but somehow text goes away from main figure and idk what to do.
Anyone knows?
tank666
Feb 3, 2021 10:10 PM UTC
Just remove the rectangle. You can customize the background color in the Auto Layout properties.
Power Member
Feb 4, 2021 1:49 AM UTC
The problem is that the “rectangle” was turned into a simple vector object at some point so it’s not actually a rectangle, just a vector object with the name “rectangle” and the look of a rectangle. This can happen if you modify it in the vector editing mode or press Cmd/Ctrl + E to flatten it. The difference that you can’t modify individual four corners in the right panel when a simple vector object is selected but can modify them on a rectangle.
Figma can only create Auto Layout objects from the objects that have the type Rectangle, and can’t do it with simple vector objects.
May 23, 2024 4:32 PM UTC
Group the text and the rectangle then stack the text above the rectangle.
