Text Alignment Buttons Bugged
Hi, I am using Figma on Safari. Since yesterday (2024/3/21) the 6 buttons on my text parameters (L-aligned, C-aligned, R-aligned, Top-aligned, M-aligned, B-aligned) start to not work properly. At first I thought they were broken, not being responsive to my clicks. Then today I realized only the upper left corners of each button respond to my clicking. The tappable area in the left corner of each button only cover 1/3 of a button’s width and height. So now I need to deal with precision clicking to work around it. Can this be investigated and fixed?
ksn
Hey @Hsing_Howard - I’m not immediately aware of any issues with that may be related to alignment/responsiveness, but I’m sorry that it’s causing problems with the buttons you’ve designed.
In terms of investigating, the first best step would be for us to try and replicate the problem. There is likely something in your design specifically that’s causing trouble (not necessarily on your end, but rather surfacing because of how you’ve set up your system).
Are you able to share a copy of the file you’re seeing this on? If so, PM me for further instructions (don’t post it here to protect any IP you have).
March 27, 2024
I am also experiencing this issue. It only recently started, and I’m on the latest version of Safari and macOS.
March 27, 2024
And I was able to replicate: I thought the buttons were totally non-responsive, but they only respond if you click the top left corner of each one.
Hey all,
Thanks for flagging. Our product team confirmed it’s unexpected and they are working on it to fix it. We will let you know once it’s resolved.
Thanks for your patience!
Toku
ksn
Hey everyone - this should now be fixed. Please let me know if you are still running into any issues.
April 28, 2024
Hi, starting today, it seems that on all my text boxes text alignment buttons are not responding thus not changeable. Could you please look at this issue?
ksn
@wgnator Can you let me know if this is still a consistent issue for you? I want to see if this is related to some issues we’re seeing related to the right-hand panel.
Also, if you’ve noticed any other issues with changing properties, let me know.
May 5, 2024
@ksn Hi, As of today, the bug does not seem to be reproducible. Thanks!
