JT9876
Mar 13, 2026 9:36 AM UTC
Taking a website design made with maker to an editable design that can be imported to Wordpress/Elementor in the future
Hi i need some help, i am trying out Figma and I’ve developed a website design in maker that my client is super happy with and now need to move it to a development site for customisation - images, copy links etc.
  1. how do i take the make design to an editable website wireframe/design that i can customise
  2. then migrate the site to my development server - so it can eventually be deployed on the clients website
  3. If i wanted to take the design and build in elementor pro is that possible? I normaly build in elementor.
any help/direction wold be appreciated.
thanks
JT9876
JT9876Author
Mar 13, 2026 9:39 AM UTC
Maxym
Aug 26, 2026 7:28 AM UTC
The native Copy design feature is the first option to try. Another possible workflow is to download the frontend code from Figma Make and import the project ZIP into Figma using Source → Design.
Disclosure: I built the plugin. It rebuilds the rendered project as editable Figma layers. It does not convert the project directly to WordPress or Elementor, so that development step would still need to be handled separately.
Plugin: https://www.figma.com/community/plugin/1671982756700161071
drzivil
Nov 5, 2026 3:41 PM UTC
To add the step that’s still missing here, Figma to Elementor (disclosure: I build ready→made, a Figma plugin for this):
  1. Make design to editable layers. Maxym’s route works: use Copy design, or import the project into Figma. Before you convert, clean the frames up a bit. Use auto layout for rows and columns instead of absolutely positioned groups, and give sections clear names. That decides how editable the result is in Elementor.
  2. Development site. Set up a normal WordPress install with Elementor on your dev server. Images, copy and links you then edit there, not in Figma.
  3. Figma to Elementor. Select a frame in Figma, choose Elementor in ready→made, then right-click in Elementor and paste. You get native containers and heading, text, image and button widgets, not one HTML block. It works with free Elementor; you don’t need Pro for the paste. I’d convert section by section, so you can check each part and redo only what’s off.
When the client signs off, move the dev site to the client’s server as usual, for example with a migration plugin.
If you like, post a frame of your design here and I’ll show you what comes out, including the parts that need manual work.
Plugin: https://www.figma.com/de-de/community/plugin/1492108013732875788/figma-to-wordpress-elementor-gutenberg-oxygen-readymade
