Alex_Getty
May 12, 2021 2:58 PM UTC
Some prototype connections lost when copying page
Description of the problem
  1. I have a set of frames with prototype connections on a page
  2. When copying that page, some of the prototype connections break. Not all of them, but some. It seems more likely to break overlays than navigation.
Does anyone else experience this issue? If so, have you found a work around?
I’m working with a high volume of prototypes that are copied and locked for sharing with clients. That way I can keep iterating on the main one and they have access to a snapshot of the prototype from our last review. Having to go through every copy I make in order to repair these links is tedious and time consuming.
AnneK
Apr 12, 2023 9:11 AM UTC
I’m having the same problem;
  • I copy-paste a prototype on the same page. In this case outgoing connections from a component are wrong (in the copied prototype, this component becomes an instance and takes its outgoing connections from the component, so it is connected to frames in the original prototype rather than the copied one). I guess this is expected behavior and easy enough to prevent. (Weirdly, incoming connections are copied correctly.)
  • I copy-paste a prototype to another page or I duplicate a page containing a prototype. In this case many more connections are lost and I cannot determine why those are lost while others stay intact. This is problematic and seems like it’s a bug.
Paul_Attard
Aug 15, 2023 3:55 PM UTC
This seems to be happening to me only for conditional interactions.
Oct 6, 2023 12:02 PM UTC
I’m having the same issue. Mainly, the conections lost are between pages.
Duplicating the page instead of copying solves it, but then creates another problem: Several components lost their customized text, returning to their component text (e.g. all buttons return to the “button” label I placed at the component)
Apr 13, 2024 3:00 AM UTC
Found a soluion! To ensure that all links are imported to the duplicated page, you need to make sure that the main component (the one you drag links from) has at least one variant before duplicating the page.
If the component only has a single instance with links, those links will not be imported to the duplicated page.
