Brian_Saunders
Aug 10, 2022 11:11 AM UTC
Some changes aren't updating in the prototype view
Has anyone had the problem lately of making design changes, but they aren’t updating in the prototype view? This doesn’t happen all the time, but when it does I need to refresh the prototype tab for the changes to appear. For example I just added a banner to one of my frames and the banner didn’t show up in my prototype until I refreshed the tab. I’ve also noticed it with smaller changes such as adding borders to elements, and the borders don’t appear.
If this is a bug it could be affecting viewers of my prototypes too, who won’t always be seeing the latest version and won’t know it. Or there will be missing elements and the prototype will look broken to them. I use the desktop app so haven’t confirmed if this is a problem in the browser as well.
Jul 21, 2023 11:18 PM UTC
Thank you @Alexandre_Batistella_Bellas! I had a similar problem and your suggestion fixed it.
Oct 15, 2023 8:49 AM UTC
Still having the same problem
What can I do\
Dec 28, 2023 1:01 PM UTC
When i click to particular link its show and then previous text issue in Figma prototype how to solve issue.
Text not updated on prototype. what to do let me know ?
Dec 28, 2023 1:02 PM UTC
Vale_Querini
Jan 2, 2024 12:58 PM UTC
Is there a way to force the prototype update?
Jan 16, 2024 12:17 PM UTC
If an object with a changed color doesn’t update, I’ve found dragging it around forces the color to update, which is a workaround… but not a very helpful one.
If this bug were a kid it would already be old enough to walk.
Waheed2
Oct 30, 2024 1:57 PM UTC
Check if its component, just frame it and relink to your prefered framw again. Hope it helps you too.
Carla16
Dec 26, 2024 1:26 AM UTC
Have you checked if the frame is overlapping an old one? This could also be a source of interference.
Chris_Gatland
Apr 8, 2025 2:38 PM UTC
I’m getting this problem more and more often too.
Strangely, I get much better synchronisation with changes when I view in the preview mode (not presentation) - ie the floating prototype window you get with a press of Shift + Spacebar.  No idea why this would be.
Sammy_Guergachi
Apr 20, 2025 4:29 PM UTC
This is super annoying! Figma present view should always work, 100% of the time!
