Yuval_Dikerman
Feb 19, 2021 8:52 AM UTC
Solved? - CTRL + ALT + C doesn't copy properties/style data anymore
Previously discussed in the old channel figma confuses CTRL + ALT + C - Making it function as Add/Show Comments instead of Copy Properties.
The solution I found was switching to a US Keyboard instead of an International English Keyboard →
Serhii_Mudrak
Feb 1, 2022 9:29 AM UTC
MAN I LOVE YOU ❤️❤️❤️SO MUCH TROUBLE AND SUCH A SIMPLE SOLUTION XDDD
How you figure that out?
Kristof_Aczel
Feb 4, 2022 9:08 AM UTC
Jesus Christ, it does work!!! NumLock needs to be enabled! Oh man, how on earth did you figure it out??? You are the MAN!!
Andrew_A
Feb 16, 2022 8:41 PM UTC
Probably another software is blocking the same shortcut. In my case it was Evernote. It used Ctrl+Alt+V shortcut for pasting.
Andras
Feb 26, 2022 9:59 AM UTC
I’m also having this issue with both the browser and Windows app version of Figma. Ctrl+Alt+C and Ctrl+Alt+V only work if I change to the English keyboard layout.
What about those who don’t have NumLock? Unfortunately I don’t have one on my laptop.
Alwyn_Balingit
Feb 28, 2022 6:28 AM UTC
I still think that CTRL+ALT+C should invoke “Copy Properties” instead of “Comments” regardless if the following are on or off:
  • EN-INTL vs EN-US Keyboards
  • Num Lock State
The bug started when they double-mapped Ctrl+Alt+C to “Comments Mode”, Not knowing that the keyboard shortcut is already assigned to “Copy Properties” as shown here for many years already:
Vlad_Loktionov
Jun 5, 2022 9:05 PM UTC
Hello. One good developer BladeMight just responded to my suggestion and offered his own workaround for INTL layouts (the best and trouble-free in my opinion) with Mahou app: at the time of typing Ctrl+Alt+ combinations, the keyboard layout will temporarily change to special one where the symbol mode doesn’t involve duplicating AltGr to Ctrl+Alt.
Just open Mahou “Layouts” tab and enter in “Temporary change layout on LCtrl+LAlt combination” field: 67699721 (English US code), then click on “Apply” button.
You can freely specify any other (desired) keyboard layout (without AltGr) code for a temporary change (but it made no difference).
Download (x64): https://github.com/BladeMight/Mahou/releases/download/latest-commit/Release_x64.zip
Other builds: Release latest commit release ([417879a] build #1242) · BladeMight/Mahou · GitHub
Here are my settings: https://i.imgur.com/Auh6xHu.png
Vinicius_Blembeel
Jun 6, 2022 4:54 PM UTC
So… still no official fix for this? I sent a support ticket a while ago and the only thing they responded to me was that was basically a one-off bug. Thought it was just me.
What would be solution for those who don’t have numlock on their keyboards and don’t have the language bar available (even if I had, my keyboard is ABNT2 (PT-BR Keyboard))?
I’m aware of @Rubem_Pechansky 's script solution but I’m not familiar enough with scripts to install it and would preffer avoid using if possible since it could lead to several other unforeseen complications.
Mushba_Said
Jul 30, 2022 1:32 PM UTC
Hi everyone,
TL;DR: if keyboard changes aren’t working for you and you have Loom installed, quit Loom.
Long story: I found this forum because I was facing the same issue. I tried the keyboard changes and it didn’t work. Then I googled the shortcut for confetti to make sure my switches weren’t causing an issue (i have a mech keyboard) and found this: Did I just find an easter egg in Figma? · Figma
Sadly this is an issue if you run Loom and Figma together -_-
Posting this here in case it helps anyone!
Niaw
Sep 2, 2022 2:40 PM UTC
Same here. I discovered that Loom was causing the problem by closing tray applications one by one until the Ctrl + Alt +C shortcut worked. Then I checked Loom preferences and found the shortcut conflict.
Anton_Yakovlev
Sep 26, 2022 11:14 AM UTC
You can use “On-Screen Keyboard” for it (shortcut is hidden in Start → “Windows Ease of Access” folder)
