Yulia_Sokolova
Apr 22, 2022 3:29 PM UTC
Right Side Bar disappeared
My Right Side Panel Menu disappeared! HELP! Control+\ does not bring it back!.
JanKragh
Apr 26, 2022 12:32 PM UTC
If the UI is hidden, use mouseclick to go to contextmenu, select “Show/Hide UI”
ezichi_gift
Aug 17, 2022 3:09 PM UTC
This is not working either
Emilie_Oswald_Macaulay
Aug 22, 2022 3:12 PM UTC
I’m having the same issue. Have you found a resolution?
Flavio_Lee_Budoia
Nov 3, 2022 12:43 PM UTC
This is a browser issue. So, if you’re using Chrome, switching to another browser solves it. Probably using the app instead also would do the trick.
No clue about why it happens, though. =/
Just happened with me and going with Safari was the only solution.
Probably updating Chrome should fix it.
Moeslein_Michael
Nov 15, 2022 12:10 PM UTC
I’m having the same issue in the browser. I can hide/show the bottom tool bar, but nothing will bring back my left and right panels.
pkp
Nov 15, 2022 1:55 PM UTC
SInce this is a really old issue I would recommend you the same as mentioned in previous comment try updating your browser. Or try in incognito may be some cache issue. Better download figma application.
Feb 25, 2023 11:13 AM UTC
This just saved my life lol. Thanks for that. Another shortcut that I MUST memorize lol.
May 5, 2023 9:53 AM UTC
Mine worked when I logged out and logged back in.
Swikar_Ramdam
Jul 11, 2023 3:59 PM UTC
Go to view>panels>show leftbar
Sep 5, 2023 4:01 PM UTC
This happens when you accidentally zoom the browser window. In chrome, go to View > Zoom Out, or View > Actual size.
From there you can toggle the panels on / off as normal using Command + \
