Jan 3, 2024 2:41 PM UTC
REST API Variables
Hello there,
A tricky one: Is it intentional that when I use the GET /v1/files/:file_key/variables/local API I can get a response that contains an alias pointing to a variable that is not part of the response itself?
        "valuesByMode": {
          "XXXX:X": {
            "type": "VARIABLE_ALIAS",
            "id": "VariableID:XXXXX/XXXX:XXX" //<- This id is nowhere else mentioned in the response.
Thank you!
jefflee
May 24, 2025 12:32 AM UTC
Thanks to help from ​@joji, I think I was able to identify the issue. It seems like the problem occurs when we have an alias chain that is at least 3 variables deep, and multiple variables are deleted.
For example, suppose we have Variable A that aliases Variable B that aliases Variable C. Then we delete Variable B and Variable C. The get-local-variables API will return Variable A and Variable B, but not Variable C.
We’ve filed a bug report for this specific issue. Please respond in thread if you think there are cases that don’t fit this description.
