tallneil
May 9, 2023 6:13 PM UTC
Reset text style to default?
Is there a way to easily reset a text style to default? When I create a new text field, it usually inherits the most recently used properties - including font family, weight, letter spacing, case, etc. This isn’t always the desired behavior, and it’s tedious to change each property 1 by 1.
Ioana_Gutau
Aug 26, 2023 10:54 AM UTC
I was also trying to find an answer to this question, as i could not find any way to reset the text to default in the current file. The ultimate solution i found, was to open a new file and paste the text there, then copy it in the current file.
Are there any other ways? This is a very easy thing to do in adobe illustrator, just click and type 😕
Naresh_Ugaonkar
Oct 12, 2023 10:45 AM UTC
I am facing the same issue have you found any solution to this yet?
Ben30
Feb 3, 2024 5:23 AM UTC
Also here with the same question. Would like the option to reset text styles back to default.
Oskar_Lewicki
Mar 21, 2024 10:50 AM UTC
I’m looking for the same functionality. It would increase productivity a lot.
John_Saunders
May 21, 2024 1:47 PM UTC
For line height you can type into the value box the word ‘Auto’ this should reset back to default. For letter spacing and paragraph spacing set value to ‘0’ 👍🏼
tallneil
tallneilAuthor
May 22, 2024 5:05 PM UTC
@John_Saunders you’re right, the user can reset each text property one-by-one. But this can be very tedious when you consider all of the text properties in addition to the ones you mentioned: alignment, decoration, case, etc.
I’m currently working on a Figma plugin that will address this issue!
Joshua_Butts
Nov 19, 2024 11:58 PM UTC
@tallneil Did you ever make that plugin? I’d love to try it out.
