Bina
Mar 1, 2022 5:25 PM UTC
Replace local components with Library components of the same name
I’ve encountered a problem and haven’t been able to find a native solution or any via plugins.
We have existing UI component libraries in Sketch, that have been re-created in Figma. When I import existing Sketch files that used symbols connected to the Sketch library, they (obviously) get imported into Figma as local components, unconnected to any library.
I want to be able to replace all these components in one fell swoop with the Figma library assets which have the same name. This page (https://help.figma.com/hc/en-us/articles/4404856784663-Swap-style-and-component-libraries) doesn’t work because these are local components, not a library.
Any one have any solutions or plugins that would solve this?
Teri_Gosse
Mar 11, 2022 7:10 PM UTC
I am having this same issue — we had our library and documentation in a single file, but now we’re splitting it up. I want to replace all local master components with instances of matching library components. Hmmm
Patricia_Cascination
Apr 28, 2022 11:40 AM UTC
Same here!
Quite annoying, since it can only swap between libraries and even if you make a library from your local file it will not allow swapping local components.
Thank you for explaining it so clearly!
Antoine
Apr 28, 2022 12:01 PM UTC
You should try Master!
Babusiaux_Guillaume
Jul 6, 2022 2:23 AM UTC
Hey @Antoine
Can you share some details on how can i achieve this with Master ?
Shane_Helm
Aug 9, 2023 10:53 PM UTC
Proper way to move components is found here:
Figma Help Center
