Edgar Quiroz
Mar 25, 2026 1:26 PM UTC
Remove library in Figma Make
Hi, how can I remove an added library in Figma Make?
I want to replace it with my main design system library.
Mar 25, 2026 5:50 PM UTC
Hi Edgar, Celine from Figma here, happy to assist! I understand that you want to remove a library from Figma Make, and replace with another one.
As mentioned in this article, once a library has been added in Figma Make, it cannot be removed if it has been used to prompt for example.
If you’d like to switch to a different library (like your main design system), the best option is to create a new Figma Make file and start generating from there using the correct library.
(If the library hasn’t been used in a prompt yet, starting fresh is still the recommended path to avoid it being referenced going forward.)
As an additional option, if you want to control visibility more broadly, you might also consider reviewing the library’s permissions/settings to limit who can view or use the library in Figma Make. Hope this clarifies!
