_Platform_Design
Apr 15, 2024 3:59 AM UTC
Questions about the main component and its relationship to instances
Hi. I’m Jun, a design system manager in South Korea.
I have a question about components.
Let’s say you have a file A and a file B.
In file A, I created a local component and used the instance on page a,b of A.
Then, if you want to use the local component from A in file B, you can do it in two ways
Option 1. Copy the local component from A and paste it into pages a,b of file B.
Option 2. Move A’s local components to a separate file and use them in B via the library after publishing.
I already know that option 2 is the preferred option, because the component needs to be published from the library so that it can be used in multiple files.
However, Figma doesn’t systematically prevent Option 1, and I can still use the local component from file A in any file.
What I’m curious about is whether the main component and instances are still fully connected, without any loss of integrity, with Option 1. I wonder if a component that is not published as a library becomes a kind of “ghost instance” that is not linked.
Power Member
Apr 15, 2024 4:05 AM UTC
It’s basically a fallback method in case you forgot to publish the component by accident. This shouldn’t be used intentionally. The instance is linked but won’t receive any updates from the main component until you publish it.
_Platform_Design
Apr 16, 2024 3:54 AM UTC
you’re right. thank you!
