wwwanyu
May 23, 2024 5:21 AM UTC
Publish library issue: modifying component settings should also trigger an update
It seems that there is an issue with the Publish Library’s logic. It appears that a new component needs to be added for changes to be recognized and eligible for publishing. However, when I modify the properties of an existing component, it is not considered a valid change for publishing.
    May 24, 2024 1:30 PM UTC
    Hey there! Welcome to the community and thanks for flagging this.
    Hmm not sure what’s causing this, I can’t replicate it 🤔. You should be able to publish the change after applying a small change to a property of the main component. |
    Do you receive any error message when attempting to publish a library? If so, you may need to adjust your network settings.
    It would be also great to have access to your file and a quick video recording when you encounter the issue so we can try to replicate it. If you are able to, please reach out directly to the support team here: https://help.figma.com/hc/en-us/requests/new
    Please use your Figma account email, include a link to the file, and add support-share@figma.com as Editor, so they can take a closer look. Thank you!
    wwwanyu
    wwwanyuAuthor
    May 30, 2024 2:58 PM UTC
    Hi Celine,
    I don’t have the “Publishing fail” message.
    In the same file, if I create a new component, it will be show as a change, I recorded the screen:
    The file:
    Figma – 27 Jan 23
    Thank you
