Karachi
Jul 8, 2024 2:52 PM UTC
Prototyping Issues
When I start the prototype, only some of the elements of the design show up. The rest is blank. How do I fix this?
Vishal_Ramawat
Jul 9, 2024 3:27 AM UTC
Those elements might be ‘floating’ over the frame and not actually nested in the frame being rendered.
Karachi
KarachiAuthor
Jul 9, 2024 11:31 PM UTC
How can I tell the difference?
Vishal_Ramawat
Jul 10, 2024 2:29 AM UTC
When you select any element, check the left Layers Panel, they should be inside the Parent/Main frame. For e.g.
The ‘Fly’ instance looks like it is inside the Frame 1, but if you see Layers Panel, it is outside of it.
Karachi
KarachiAuthor
Jul 11, 2024 2:25 PM UTC
I think the issue was that I was using sections to house some of the elements. I replaced them with regular boxes and that seems to have fixed the issue.
Thank you for your help.
Hiba_Fathima
Jul 12, 2024 6:46 AM UTC
Hey, if you want to create interactive product demos directly from Figma, you can also check this Plugin we built - https://www.figma.com/community/plugin/1382781944686485388/supademo-create-interactive-prototypes-from-figma
It helps you create interactive prototypes in < 5 mins
