Annieck
Prototype shows different for different users
Hi,
I’m having some trouble with Figma since the update.
For example I have a header. It has a main navigation menu and above the navigation menu it has a mini menu with some items.
The four items in the mini menu have a hover effect.
I made this by making an instance in the correct font, and then a second variant with the same font but bold.
I then used prototype to ‘while hovering change to variant 2’.
I added four instances in auto layout, and changed the text so the 4 items have the correct names.
When I play one of the pages with the header in prototypes everything works fine.
But now, which is my problem, when I ask one of my colleagues (developers or managers) to play the prototype the hover effect does not work. The text becomes bigger but not bold. They mainly use the web app but I tested some stuff with one of our devs in the app and the web app which both did not work for him.
So long story short:
The prototype works fine when i play it, but when anyone else plays the prototype it does not work.
How can we fix this?
Annieck
AnnieckAuthor
2024-02-01 10_31_21-Website - EPIC IT - Website - Figma
2024-02-01 10_44_28-Website - EPIC IT - Website - Figma
2024-02-01 10_44_07-EPIC IT - Website - Figma
Annieck
AnnieckAuthor
We tested some more, and we found out I’m the only one with the fonts installed on my PC. When my colleagues install the fonts the prototype suddenly does work.
Is there any way to go back to before where they don’t need to install the fonts to still see a working prototype? This is also very annoying when we have to present the prototype to our customers at their own locations because now I would have to bring and install the fonts on their PC’s whenever we are presenting the prototype on their devices.
Hi there,
I understand your frustration regarding the issue with missing fonts. For text characters to display correctly, the necessary fonts must be installed on their laptop.
Regrettably, this means you might need to choose an alternative font to ensure all text is properly displayed. For guidance on how to select a different font, please refer to this link: https://help.figma.com/hc/en-us/articles/360039956994#select-font.
Thanks for your understanding.
Toku
Annieck
AnnieckAuthor
Hi y_toku,
Thanks for the reply!
Will this ever come back to Figma, because before we had no problems with this
Kind regards!
April 10, 2024
I have this problem too. It was fine before but now all of a sudden no one sees what I see. The interface doesn’t render all elements for others and in some places it’s glitchy e.g. text is scrambled. What’s interesting is most text is rendered in the correct font which is only available on Adobe Fonts.
It sounds weird! According to our internal team, we may have a possible issue in fonts, so could you reach out directly to the support team with a copy of your file: https://help.figma.com/hc/en-us/requests/new?
Toku
