James_Chung
May 6, 2021 6:36 AM UTC
Prototype "Back" is not working in my prototype somehow
Hi Guys, i was create the “back” interaction. I set up as “tap” + “back” on an arrow. However, when i present, it doesnt go back to the previous screen. It seems like there is no interaction exist at the arrow.
May i know if the above set up is correct? Do i need to do extra links or set up in order for the arrow to work as “back” ?
Thank you!
Marketa_Konecna
Feb 12, 2022 12:26 PM UTC
Hi, I had the same problem. I went back to design interface and in “stroke” area I changed from “inside” to “outside”. Now it is working. Hope it will be helpfull. 🙂
Jul 24, 2023 8:57 AM UTC
Thank you so much!
Sep 20, 2023 12:22 AM UTC
omg! this worked for me. Thank you so much!!!
Oct 6, 2023 4:36 PM UTC
OMG you are a saviour! I have been trying so hard for the past 24 hrs … posted this question on random youtube videos and your trick worked. Thanks a tonn!
Nov 30, 2023 2:20 PM UTC
It worked!! Thank you
Tyrone1
Mar 24, 2024 7:28 PM UTC
Just a little addition here since I found myself coming back to this thread for the same issue again. The first time I had this issue, setting the stroke to ‘outside’ seems to have worked. However in a second version of my project I couldn’t get it to work properly again.
My solution was to simply expand the height of the frame the arrow was in and center the arrow in it. I think the issue was that because the arrow was just a stroke with a height value of ‘0’ (the arrow pointer is just a “decoration” to the stroke), the frame also had a height of ‘0’ which made it impossible to click. I changed the frame height to ‘15’ in my example and it worked fine with no other changes.
I’m not 100% sure my theory on why it wasn’t working is correct, but fixing the frame height did solve my issue.
If I’m correct in my assumption about the 0-value height, then flattening the arrow to make it a vector shape should also fix the frame height to the full height of the shape, at the expense of losing some editability.
EdwardChen
Apr 13, 2025 12:16 PM UTC
it worked,  thanks !!!
