Max Ruso
Project too large try deleting files
The error message above prompt says : Files that are too large
large files break figma make but i have deleted some of those files and it still stock on same message
ksn
Hey ​@AIGent John - I also received your PM, and will respond to you there! Just wanted to acknowledge here as well :)
Riadh
le message d'erreur : Projet trop volumineux, essayez de supprimer certains fichiers” ID de la demande : b576b663-d70b-4ead-8eb7-69
[Moderator note: This topic was merged from “le message d'erreur : Projet trop volumineux, essayez de supprimer certains fichiers” ID de la demande : b576b663-d70b-4ead-8eb7-69” into “Project too large, try deleting files” on Feb 22, 2026.]
QQuaan
Hi, I also got the message Project is too large, I only use 1 frame and try to make create an website with Figma Make. I’m trying to break into some smaller frame for this.
Request ID: e09b7c76-6419-489c-8e81-79e2fa14deb6
My memory is only 25%, so I think it’s fine
Riadh
Hello,
My Figma project no longer loads (blank canvas and empty left panel).
Older versions were temporarily accessible but now the entire project fails to render.
Request ID: b576b663-d70b-4ead-8eb7-69…
It seems the project exceeded a server-side size threshold.
Could you reset or repair the file from your backend?
This is critical work and I’m the only user on a Professional account.
[Moderator note: This topic was merged from “Error” into “Project too large, try deleting files” on Feb 22, 2026.]
Tom Reem
Hey ​@Riadh — thanks for calling this out, and sorry you’re running into this.
A few other designers have reported a similar error message recently, so I’ve merged your posts into a related topic where we can track this issue in one place. I’m looking into your report now and will follow up as soon as I have more to share.
Thank you for your patience.
Tom Reem
Hi ​@QQuaan and ​@Riadh — thanks again to both of you for flagging this and for your patience while I followed up. The details you shared about the error message and memory usage are really helpful.
When you have a moment, could you try the troubleshooting steps that ​@djv shared earlier and let us know if that helps move things forward?
If it’s still not working after that, please check the email inbox tied to your Figma accounts and reply to the message there with the requested info. I’ve opened cases with our Technical Quality team so they can take a closer look at the files involved:
  • ​@QQuaan, your case number is: 1758748
  • ​@Riadh, your case number is: 1758164
Not that, in order to take a deeper dive, they’ll need:
  1. view access granted to support-share@figma.com for the file(s) showing the “too large” error.
  2. the file name(s) and URL(s).
Thanks for working through this with us — we’ll keep digging until we get this sorted.
Riadh
VSSeshaSaiJayanthGorugantu
This error persists even if I save it to local storage and upload it to figma. Dont have anything left to delete from the file. Please help.
Gayani_S
Hey ​@Riadh, ​@Tom Reem is out of office today, but I’ve added your screenshot to your support ticket (#1758164).
In the meantime, as Tom previously recommended, could you please share the impacted file with support-share@figma.com and grant “Can View” access? Having direct access to the file will allow us to reproduce the issue and partner with Engineering to investigate more thoroughly.
Really appreciate your help with this!
AIGent John
I had to give up because of a lack of response.
My only solution was to roll back to an earlier version and then try to delete files or restructure large files.  I lost at least a week of coding until I found a version that I could roll back to.   If this happens again, I will not stay on Figma.
