Paul_Boag
June 27, 2024
Problems with Design Mode on Figma Slides
Is anybody else getting the following error when they try and use the design mode in Figma Slides:
Figma slides design mode requires a Figma design plan
And yes, before you ask, I am logged in on an account that has a design plan seat.
Paul_Boag
Paul_BoagAuthor
June 27, 2024
Just to let you know if you have the same problem, the issue is caused when you create the slides in drafts rather than a team/project. If you create it in there everything works fine.
June 27, 2024
I was also having this issue. It automatically switched to design mode when I started manually adjusting some auto layout spacing on the slide—but now it won’t let me toggle back. I quit and reopened and it went back to slides mode but now I’m getting that design seat error again. I’ve moved it out of my drafts but that hasn’t seemed to fix it 😦 It seems like the toggle is just buggy?
Hi there,
Thanks for flagging. I’m checking this behavior with internal team and will get back to you once I have any updates that I can share with.
Thanks for your patience!
Toku
Russell_Phillip
Figma Slides needs a lot of work… I tried using it. It’s literally easier to design a presentation in Figma, not Slides.
Eliot
June 30, 2024
@Paul_Boag I just experienced this issue as well but was able to fix it by duplicating the Slides file and working from the duplicate, immediately the toggle worked again. Before that I tried logging out and reinstalling Figma to clear the cache but that didn’t fix it, had to duplicate the file and then deleted the original.
Hi all and @Ali_Doucette ,
Our apology for the confusion. Our team confirmed it was a bug and they fixed it. If you still see this issue, please feel free to let us know!
Toku
July 1, 2024
Awesome thank you Toku! Slides is so great, I’m a big fan!
July 2, 2024
Still having the same issue
Can you try this?
Figma Learn - Help Center
I hope this clarifies it!
Toku
July 7, 2024
I have the same problem. I have moved my file to the team project. But it still doesn’t work and show ‘Design mode requires a Figma design plan’.
