maryam0808
Nov 3, 2026 10:01 AM UTC
problem with the card componets
Hi guys
I have some problem with my product card componets.
I want to do the hover which when you hover on the cards, the picture would be a little bit bigger.
Like a zoom effect.
But when i put different pictures in the copys of that component , It will just read from that main component and shows me the picture i used there in hover.
Do i have to do it individually for every picture? or am i missing something in the way i do it?
    Ondrej_Pavlicek
    Figma Ambassador
    Figma Ambassador
    Nov 3, 2026 10:48 AM UTC
    Hi there! 👋
    Thanks for sharing your question. Could you please share a bit more about how your parent component or layout is structured?
    Also, describing how your layers are arranged would really help figure out why the overrides aren't behaving as expected. 😊
    Product designer @ NETWORG | Designing Model-driven Power Apps in Figma | Power Apps DesignKit (Model-driven) | Disclosure: I’m part of Figma’s Forum Ambassador program.
    maryam0808
    Nov 3, 2026 11:10 AM UTC
    Thanks for responding
    Here is a video and some screenshots of my parent component and layers, i also set both pictures on crop. would that be the problem?
    and i did also add a video of how it will act when i change the photo.
    Ondrej_Pavlicek
    Figma Ambassador
    Figma Ambassador
    Nov 3, 2026 11:58 AM UTC
    Thanks for sharing those details.
    I was wondering about that group in your layers. If you have text or other elements inside that same group, could it be that the whole group (including the text) is scaling up during the hover effect?
    If the zoom is applied to the entire group instead of just the picture rectangle, that might be causing the unexpected behavior. You could try simplifying it by removing that group and keeping just the image layer.
    To give you an idea, I tested this myself by creating two quick demos and everything works as expected when structured properly:
    Here is how my layer structure and component states look:
    Rondolg
    Nov 3, 2026 11:51 AM UTC
    You don't need to do it individually! This usually happens if the layer names inside your component variants don't match exactly. Make sure the image layer has the exact same name in both the default and hover states. Figma needs this to preserve your image overrides when prototyping.
    maryam0808
    Nov 3, 2026 12:05 PM UTC
    Oh i see, so that is why. thank you for your respond.
