POST Method - Help
  • June 20, 2023
  • 761 views
Hi Experts -
I am new into REST API development. We are looking to integrate with Tradeshift using REST API.
I am able to connect to Sandbox server and able to get the GET the document or invoice created manually.
Now we need to create new document or invoice using POST Method but I am getting 415 Unsupported Media Type.
URL used while POST -
https://api-sandbox.tradeshift.com/tradeshift/rest/external/documents/dispatcher
Documentation says -
Send Document
Description
Store and dispatch the document - the actual document content must be sent as the entity/body of the POST call.
documentId
  • REQUIRED
A client-generated id for the new document to be dispatched
  • IN: QUERY
  • TYPE: STRING
documentProfileId
  • REQUIRED
The document profile id that the document adheres to (e.g. "nes.p5.invoice.ubl.2.1.dk"), from the ‘documentprofiles’ resource
  • IN: QUERY
  • TYPE: STRING
documentSource
Track the document’s source - We save the source of the document in a new table called documentsource so that we know where the document was dispatched from.
  • IN: QUERY
  • TYPE: STRING
JSON Received by GET METHOD
“itemsPerPage”: 25,
“itemCount”: 1,
“indexing”: false,
“numPages”: 1,
“pageId”: 0,
“Document”: [
“DocumentId”: “57294446-39e0-47ae-b695-cf56fc3d9e8c”,
“ID”: “INV1133”,
“URI”: “https://api-sandbox.tradeshift.com/tradeshift/rest/external/documents/57294446-39e0-47ae-b695-cf56fc3d9e8c”,
“DocumentType”: {
“mimeType”: “text/xml”,
“documentProfileId”: “nes.p5.invoice.ubl.2.1.gb”,
“type”: “invoice”
“State”: “PROCESSING”,
“CreatedDateTime”: “2023-06-13T10:39:45.944Z”,
“LastEdit”: “2023-06-13T10:40:36.553Z”,
“Actor”: {
“Created”: “2023-06-13T10:26:55.688Z”,
“Modified”: “2023-06-13T10:26:55.688Z”,
“FirstName”: “Gurjeet”,
“LastName”: “Singh”,
“Email”: “gurjeet.Singh@gmail.com”,
“MobileNumberVerified”: false
“ConversationId”: “c173cf9f-d6a7-437c-b9af-7bfb51bbfbbd”,
“ReceiverCompanyName”: “ABC”,
“Tags”: {
“Tag”:
“ItemInfos”: [
“type”: “document.description”,
“value”: “description field for 1 week”
“type”: “document.total”,
“value”: “223.00”
“type”: “document.currency”,
“value”: “GBP”
“type”: “document.issuedate”,
“value”: “2023-06-13”
“type”: “invoice.due”,
“value”: “2023-06-17”
“LatestDispatch”: {
“DispatchId”: “42cb64ca-9edf-4a15-9f46-9900a04e42c4”,
“ObjectId”: “57294446-39e0-47ae-b695-cf56fc3d9e8c”,
“Created”: “2023-06-13T10:40:36.515Z”,
“SenderUserId”: “d94bddf1-6657-4bfd-8226-fd58d08d4e8a”,
“DispatchState”: “ACCEPTED”,
“LastStateChange”: “2023-06-13T10:40:36.515Z”
“SentReceivedTimestamp”: “2023-06-13T10:40:36.049Z”,
“ProcessState”: “PENDING”,
“ConversationStates”: [
“Axis”: “PROCESS”,
“State”: “PENDING”,
“Timestamp”: “2023-06-13T10:40:36.049Z”
“Axis”: “DELIVERY”,
“State”: “PENDING_CONNECTION”,
“UnifiedState”: “PENDING_NOT_A_CONTACT”,
“CopyIndicator”: false,
“Deleted”: false,
“DueDate”: “2023-06-17”,
“TenantId”: “27762e54-2f16-4895-8c60-f2ea88c9ef75”,
“Properties”: [
“scheme”: “documentSource”,
“value”: “UI”
Hello gurjeethome,
Wondering if you have since figured this out. We just started a 3rd party integration with tradeshift and there API documentation and support ecosystem is among the worst I’ve experienced. I have the exact same need as you, and cannot figure out how to create a document programmatically.
Best,
Average Joe
Hi Joe -
Thanks for your message - I am able to GET , PUT the document but POST is still not working. I have raised the concern with Tradeshift Support and they are saying that Customer (NHS in our case) needs to approve first and then they will help.
I will keep you posted and please update if you find the way to create new document.
Thanks
Gurjeet
