James_Stables
April 10, 2023
Position sticky: I want sticky frame to fix on top of scrolling frames not below
  • April 10, 2023
  • 17 replies
  • 15181 views
When I use the new Position Sticky feature in Prototyping, the frame that sticks to the top always sits below the frames that scroll. This doesn’t make sense because the point of sticking a frame is so that it sits on top of all scrolling content.
Do I have to re-order the layers somehow? Do I have to check an extra box to make the frame sit on top of all others?
Thank you
Best answer by James_Stables
UPDATE: I finally found it!!!
You need to set the parent frame to “First on Top” which is deeply and frustratingly hidden in the “Ellipsis” (go figure) in Auto-Layout. OMFG
James_Stables
James_StablesAuthorAnswer
April 12, 2023
Roxanne_G_UX
July 10, 2023
OMG Thank you!!! I was losing it
September 23, 2023
Thank you!!! same here
October 3, 2023
Thank you so much @James_Stables !
I spent almost 2 hours trying to figure this out! 🙌
November 26, 2023
Thanks a ton @James_Stables You saved me a lot of time!
December 29, 2023
Thank you so much man!
Margs_Plaisted
January 11, 2024
Thank you! You saved me a lot of time too!
Robin25
April 6, 2024
Thank you I set the content I wanted to be on top to “First on Top” but I forgot to do it on the parent frame. Now it works nicely 🙂
Anton27
April 22, 2024
You are life saver! 🙏
May 15, 2024
Thanks man! Another thing I have noticed is that the positioning of the sticky scroll is limited by the height of the parent container. For example, a sticky navbar is positioned above a hero banner, with both contained inside a header. The scrolling interrupts the sticky header based on the height of the header.
