Sayalee_Rakh
Oct 24, 2024 5:27 AM UTC
Pink lines/Dot - what does it mean?
I’m assuming the horizontal lines are the autolayout gaps and the dot indicated the centre - but what is the purpose?
It also immobilised the instance and I can’t move it around.
Thanks!
Jeroen2
Oct 24, 2024 7:09 AM UTC
There are a few things that I can think of, which you can check:
  • Is the instance locked?
  • Is the instance inside of a frame that has autolayout?
Pavel_Kiselev
Power Member
Oct 24, 2024 7:39 AM UTC
You can drag the dot to rearrange elements in your selection. Moreover, you can use the dot to select multiple layers and rearrange the whole group
BramWerink
Oct 24, 2024 2:29 PM UTC
Adding to this, the lines show the spacing between elements, which can be changed in the right toolbar (In Xd you can only change these by dragging, so that might cause confusion)
You probably cant move them around because they are in a parent ‘auto layout’ frame.
tank666
Nov 4, 2024 4:12 PM UTC
