Attila_Bujdoso
Jan 26, 2021 10:42 PM UTC
PDF export - text not selectable
Hi all, I created some designs that I exported as PDF. I have two problems with the result:
  1. The text is not selectable (I tried Mac’s Preview and Safari).
  2. The files are rather large (1MB for an A4 size design, no images or vectors, just a few text bozes.
Any ideas how to overcome this? (I would try to avoid bringing it back my design to Sketch.
Bronwyn1
Sep 10, 2025 9:52 AM UTC
Only thing that has worked properly for me so that I can open in Adobe and edit text. Not prefect so far but the only thing that worked
Jorge_Rebate
Jan 12, 2026 1:06 PM UTC
Posting the alternate solution here from @Jane_Castellani, since Spectrum is not longer active.
Export to PDF, AND keep text selectable in 2 steps
There is a way I know to convert from Figma to PDF (keeping editability: ability to select, copy and paste the text in the new document)
STEP 1. Simply export your frames as SVG, but be sure to remove the check mark in the “outline text” option, within the options to export SVG (three points, see image).
STEP 2. Now go to CLOUD CONVERT web page, and select convert from SVG to PDF or simply click on this direct link: SVG to PDF | CloudConvert. Then select the SVG files to upload (there is an option to unify several SVG files as a single PDF document) and press the “Start Conversion” button.
This solution is so usefull if you need to label the document for accessibility ;) Thanks so much
DevDevelops
Feb 27, 2026 8:33 AM UTC
Hi! I recently developed a Figma plugin, TrueText PDF, that enables exporting PDFs with selectable text instead of flattened text.
I’d really appreciate it if you could give it a try and share your feedback.
https://www.figma.com/community/plugin/1608786203490497687/truetext-pdf
Jorge_Rebate
Feb 27, 2026 9:10 AM UTC
It’s not working rigth now?
It’s stuck in the same % when i try to export.
Exporting with TrueText
DevDevelops
Feb 27, 2026 9:34 AM UTC
​@Jorge_Rebate  Thank you so much for reporting the issue. The issue has been fixed. You can try reloading the page once and then try to export again. Let me know if it works for you this time :)
StudioAgx
Feb 27, 2026 11:03 AM UTC
Hi,
Feedback - I tried it on 5 slides and it crashed midway through the download. Then I tried it on a single slide, and it was able to export into PDF. But not all text was selectable.
DevDevelops
Feb 27, 2026 11:16 AM UTC
Hi,
Hey ​@StudioAgx, thanks for the feedback. I’ll try to resolve it to the soonest. Is it possible to share the screenshot of the text block which is not being selected. It would be a great help for me to debug the issue.
