Thomas_Cramer
Jun 26, 2024 7:54 AM UTC
Pasted Illustrator vector art in Figma is scaled πŸ“
Hi
I have an issue, where my icons are designed in Illustrator. When copying the icon from Illustrator into Figma, the artwork is scaled up.
An example from Illustrator (20px X 18px):
After pasting into Figma (26.68px X 24px):
The funny thing is, that if I create a basic square in Figma sized 16px X 16px, copy it as svg from Figma and paste it in Illustrator, it is still sized 16px X 16px. Then when copying that same square from Illustrator that I just pasted from Figma and paste it back into Figma it is scaled up.
I’m aware that I can β€œjust” scale the icon in Figma after placing it, but it is very inconvenient - especially if you have a large icon library designed in Illustrator.
Any idea what is causing this?
Thanks!
GlebSolution
Power Member
Jul 29, 2024 8:50 AM UTC
This likely depends on the DPI of the document you are copying FROM. Not much Figma can do here, this needs to be adjusted in Illustrator. Figma’s workspace is set at 72 DPI.
Oce_BTP
Sep 24, 2024 9:42 PM UTC
This for sure is a new issue. I used to copy some vector icons from Illustrator to FIGMA. All sized the same. Just came across this issue and ended up here! Seems stroke weights are also scaled up.
Thomas_Cramer
Sep 25, 2024 6:53 AM UTC
Hi @Oce_BTP
Did you try changing the resolution of your Illustrator file? That was a workaround for my issue.
Oce_BTP
Nov 8, 2024 12:13 AM UTC
@Thomas_Cramer I did! Saw a few folks doing the same. When I got updated to the latest UI3 in FIGMA seems everything got resolved. Thanks for the suggestion! 🙏
