Nov 26, 2023 2:26 PM UTC
Paragraph spacing do not work
Hello, i have a big problem !
When i’m changing my paragraph spacing in my text style, it doesn’t change my text… In my example, you can see i set the paragraph spacing to 91 (huge spacing) but i still have a kind of 20.
It’s working for other properties. I’ve restart Figma but still have the issue.
Please help me, thank you
Laura_Elizabeth
Jun 25, 2024 8:22 AM UTC
Done, thanks!
Paul50
Jul 15, 2024 5:27 PM UTC
Same problem here. Changes to text styles don’t apply when there are multiple text styles in the same text box.
KelseyONeill
Jul 26, 2024 2:45 PM UTC
Bump. same issue here. Must be a new bug, cause I know I have had different styles in one box before.
Jul 30, 2024 2:53 PM UTC
Hi everyone, we appreciate your patience! Our engineers have looked into this further and determined that this behavior is due to a feature limitation. Figma uses the style on the first character in the text box to set the paragraph spacing for the entire text box. We have submitted a feature request to bring this to the attention of our product teams.
Thank you once again for bringing this up and for your patience!
Julija4
Aug 12, 2024 2:37 PM UTC
I have the same issue. I found out that this issue only occurs if you copy paste text. If you type the text manually into the text field the paragraph spacing is working.
A little bit ridiculous 🫣
julijacreates.com
Malte_Euler
Aug 26, 2024 1:20 PM UTC
Hi,
When i have multiple styles in one textbox, the values of the first Style will override the others, so if a H2 is in at the start, that maybe has 0 paragraph spacing set, it will override following styles. Changing the paragraph spacing setup for the headline changed the styles for following paragraphs as well. its a hack, but for me it worked.
