Valter_L
Sep 20, 2023 2:04 PM UTC
"Open overlay" resets main component scroll position BUG
Issue: Open overlay resets parent frame scroll position, even tho it is not checked. (Only new state prototype ones are scrolling up)
That’s it, as simple as that. I don’t know why.
Ryan_52
Technical Quality Specialist
Sep 20, 2023 7:22 PM UTC
Hi @Valter_L I’ve tested this from my end but are unable to reproduce the issue. Can you try clearing your cache and see if it still recreates? If so mind sharing a example or video?
Sep 20, 2023 11:40 PM UTC
I’m having the same issue. Opening overlay resets the parent frame scroll, and checking the reset button and turning it back off does not change anything.
Fernando_Lins
Sep 21, 2023 3:29 AM UTC
@Valter_L @lindsey_duong Could you please try using the same prefix for your page and overlay frames, for example “Home / Page” and “Home / Overlay” and see if that fixes the issue?
Valter_L
Valter_LAuthor
Sep 21, 2023 7:16 AM UTC
Tried it, but it didn’t. It seems to be a flaky bug, since if I create a blank project and do it exactly the same way, it works. On the other project where there are old relations & new ones, same settings cause it to jump to top.
Valter_L
Valter_LAuthor
Sep 21, 2023 8:03 AM UTC
Figma – 2 Sep 22
There are 2 identical settings here, one jumps to top, other doesnt. (the one that doesnt is a blank new frame, where popup modal was added the same way.
Ryan_52
Sep 21, 2023 6:18 PM UTC
Thank you for the clarification and example. I have passed the information along and we are investigating further with our engineering team.
Eliana_Cancinos
Sep 21, 2023 8:29 PM UTC
having the same issue, one file we made yesterday works perfectly and one we made today has this problem
Valter_L
Valter_LAuthor
Oct 5, 2023 1:01 PM UTC
Has there been any updates on this topic?
Ryan_52
Oct 5, 2023 4:53 PM UTC
It appears that this issue is isolated to the main components and doesn’t affect instances of those components. Could you please share the specific use cases or scenarios where you are using a main component instead of an instance?
POPflow_Design
Nov 8, 2023 5:15 AM UTC
Any luck on this one? I’m dealing with the same issue. 😦
