Onde vejo a fonte que meu texto está utilizando?
  • June 3, 2024
  • 384 views
NUCKS_FF
depois dessa atualização não achei mais as opções de fontes que tinha antes o tamanho do texto e nem que tipo de fonte ele está usando
  • Figmate
  • June 5, 2024
Hi @NUCKS_FF, Thanks for reaching out about this! I understand how frustrating it can be when something doesn’t work as it used to.
If you have edit access to the file, when you select the text layer, you should be able to view the text properties in the Text section located in the Design tab of the right sidebar.
If your access is view-only, upon selecting a text layer, you can check out the Typography section in the Properties tab of the right sidebar.
For more detailed guidance, you might find these articles helpful:
I hope this helps a bit! If I’ve missed anything, please let us know. It might be helpful to attach a screenshot of your entire Figma screen in such cases.
Also, if anyone from our community has further insights or suggestions, feel free to share them here.
Thanks again for reaching out.
