Elise_Bjorner
Mar 24, 2025 1:27 PM UTC
OK not using autolayout?
HI
I am struggling to learn autolayout and heard from a Figma pro that it isn’t necessary for the end result. Is this correct? If not, how much worse will the end result be without autolayout?
Apolline
Mar 24, 2025 1:50 PM UTC
The end result can be the same as with autolayout, but any time you will need to add or change something to your design you will need to do it manually instead of having auto layout do it automatically for you.
Designs always evolve, and you will need to change them. Auto layout make it so changes don’t take as much time because you’re not trying to align everything perfectly everytime a new icon is added, or the text is changed.
Elise_Bjorner
Mar 24, 2025 1:54 PM UTC
Thanks. Does this apply also the the end result on screens/online?
Apolline
Mar 25, 2025 2:41 PM UTC
The end result isn’t the issue.
Elise_Bjorner
Mar 25, 2025 4:01 PM UTC
Ok so it’s the process and the time it takes that is the issue. That is it more efficient.
Nate_G
Power Member
Mar 25, 2025 11:37 PM UTC
Auto layout is also helpful building responsive and interactive components for prototypes like accordions, which can expand or collapse content, etc.
Nate G
