Ming Chang
No export library button for Figma Make, also can't access import Figma file from Make
as title, I’m trying to use my published library in a Figma Make project, but the export for Figma Make dialog does not pop up. Also when I click Import From Figma in Make, it does nothing. Tried closing the app and reopen but still the same. I’m on a pro education plan. Is this feature available for me? thank you
Tom Reem
Tom ReemSolution
Thanks for letting us know, ​@Annisa Avrillia! I just checked in with our Engineering team and wanted to share two quick updates:
1) Import from Make button and workflow
Good news here: Our Engineering team has identified the root cause and deployed a fix. Please reload your tab and try again — the Import from Figma option should now work as expected. ✅
2) Export for Make button and workflow
This appears to be a separate issue from the one above. To help our Technical Quality team dig in further, it’d be great if you could share access to the file where this is happening by filling out this secure form.
When you do, please include:
  • a link to the file where you’re seeing the issue
  • Can edit access for support-share@figma.com
  • a short screen recording showing the issue in action.
Thanks so much for your help — it really makes a difference in helping us get to the bottom of things! Please let us know if you notice anything else.
Gayani_S
Hey ​@JNTHNMLLR, thank you for reaching out!
If this is happening in the desktop app, could you please confirm that you’re running the latest version (build 125.8.9 or later)? You can also double-check your system compatibility here: Figma System Requirements.
If the issue happens in the browser version, please let us know which browser and version you’re using, that’ll help us narrow it down.
Our Technical Quality team would be happy to take a closer look at what’s going on. You can reach out to them via this form, when reaching out please include:
  • A file link (invite support-share@figma.com with “can edit” access — this won’t affect your billing), and
  • A short screen recording showing what happens when you try to export or import
This will help us get a clearer picture. Thank you for your help!
JNTHNMLLR
Hi, thanks for your answer.
I’m already in contact with the support. Let’s hope this issue gets resolved quickly.
Regarding your other questions, I’m on the latest build: 125.9.10
Happens also in Safari 26.0.1
Gayani_S
Hey ​@JNTHNMLLR, thanks so much for the follow-up and for sharing those details. I’ve added this information to your support ticket so our team can review it more closely.
Please don’t hesitate to reach out if there’s anything else I can do to help in the meantime.
SoliHub
Hi !
Same here, no export to make and even after publishing, no modal to export to Make.
Same on Desktop app (latest update) and Web
Gayani_S
Hey ​@SoliHub, thanks for flagging this! I’d also recommend here to reach out to our support team via this form.
Our Technical Quality team would be happy to take a closer look at what’s going on. When reaching out please include:
  • A file link (invite support-share@figma.com with “can edit” access, this won’t affect your billing)
EKSKEKSK
Same here, I can’t see the Export for Make button either.
Mecrano
​@Tom Reem Hey folk, I’m getting the same error at my library, this is solved? can you help me please
I have a Edu Plan
Yulia 000
Same here. Education plan, no Export to Make button. I’ve already submitted a support request.
Hey ​@Yulia 000 , for Education plan, this is expected.
I replied to you via another thread, please check it when you have a moment. Thank you!
Rob15
Been trying to figure this out for weeks. Not seeing any of our libraries in Make. Finally realized that the thing that looks like an ad is actually the UI for this. But my button is gray. Why is that?
