Nested component properties not updating with main component
  • May 27, 2024
  • 755 views
DanielBang
I have a sidebar component
my issue is, whenever I turn on collapsed state, the icons from the nested components are not following into the nested one. its all inside the same component
DanielBang
  • May 27, 2024
I’ve noticed that some icons do carry over, while others don’t, the “News” and “Dashboard” icon is still there, but the others dissapear for some reason
DanielBang
  • May 29, 2024
bump - does anyone have a solution to this??
  • June 7, 2024
Hey @DanielBang, so sorry for the delayed reply!
From what you’ve shared, this sounds due to feature limitation. It’s not possible to push overrides to a component that’s nested within another component. You will need to make those changes to the main component itself.
More info on how applying overrides to instances works is available here:
Figma Learn - Help Center
