figma-1682
Oct 6, 2022 1:19 PM UTC
Need support for export PNG files with no alpha channels
When I was working on App Store screenshots, I received an error message “image can’t contain alpha channels or transparencies”. I tried to fix this error using this plugin, but it also did not respond well. Export Opaque PNG | Figma Community
It would be extremely beneficial if we could export PNG files with no alpha channel.
Tobi_Santoso
Oct 17, 2022 10:50 AM UTC
same, any solution so far?
Tobi_Santoso
Jan 24, 2023 2:42 PM UTC
Well… u just change export png to jpg and it work lol
Michael_Ivanov
Aug 10, 2023 7:40 PM UTC
if you work on mac, you can rewrite your png files without alpha
  1. Open your file with preview
  2. CMD+Shift+S made a duplicate
  3. CMD+S open save’s settings - here you need uncheck “alpha” and tap save
    Optional: you can delete “copy” from duplicate name and it’s rewrite the original
  4. Check info by right click and you will see “Alpha channel: NO”
Feb 16, 2024 11:47 AM UTC
If you’re familiar with command line / Terminal…
gist.github.com
But yes, Figma should add the option to Include/Exclude alpha channels (or to flatten the exports, esp when there there is a solid background).
coodersio
May 15, 2024 1:52 PM UTC
Please let me know if this could help? if not , I can add new feature, thanks!
Figma
josh_on
Aug 5, 2024 12:25 AM UTC
You can open multiple files at once, then export them all as pngs - you have to expand the options and uncheck alpha - you can save over your originals.
Since most of us are here because we are exporting files for the app store, the other common bug is Figma will export PNGs at a different size from the frame. I put all my frames in a wrapping frame with auto layout, and make sure the surrounding frame is on exact pixel coordinates and the gap is a round pixel number. Then select all the individual frames and export.
