NEED LINEAR,RADIAL,ANGULAR,DAIMOND Gradient values with angle values without DEV mode/provide direct CSS for all gradients without DEV mode
Hello, Im facing this issue im unable to get the linear gradient code with angle value to write in css its better if we have lineargradient values with angle so its easy to write code, not only linear NEED LINEAR,RADIAL,ANGULAR,DAIMOND angle values mentioned in Figma GRADIENT SETTINGS (OR) provide full gradients if used that css/values including angles with out any DEV Mode
NOTE: NEED LINEAR,RADIAL,ANGULAR,DAIMOND Gradient values with angle values without DEV mode/Provide direct CSS for all gradients without DEV mode
PLEASE FIX THIS BUG IN FIGMA IM UNABLE TO WRITE CODE FOR GRADIENTS WITHOUT DEV MODE
Your valuble user,
Akhil
bunnyakhil2@gmail.com
+1 major regression
Hi @AKHIL_BUNNY ! Thanks for your feedback. I see on our backend that you have filled out a ticket, and we would like to investigate it further. Can you please reply to the support team so we can have a deeper look to your case? For your reference, your ticket number is: 949903.
@m1Y84n Can you also please reach out to the support team directly via this form for help: https://help.figma.com/hc/en-us/requests/new ?
Please use your Figma account email, include a link to the file, and share it with support-share@figma.com, so they can take a closer look. Thank you!
April 26, 2024
too high friction - will just wait on the fix from OP’s ticket
