Lara21
October 27, 2023
Multiple entry points to same flow
  • October 27, 2023
  • 310 views
I have a complex prototype where there will be a key task with multiple entry points to it through out the app. I am trying to figure out if it is possible with variables to achieve the following:
once the task flow is completed and they click “done” it will drop them back at that original entry point.
Right now I have duplicate flows for each entry point…
Pavel_Kiselev
Power Member
October 27, 2023
In theory yes, you can try conditional logic here. Something like you define the variable “flow-name” and at the entry you set some value like “flow-1”. At the end the back button to check “if flow-name == flow-1 navigate to Frame 1”
Interesting, I had few prototypes that does very similar things, will try myself when I had a chance
