KatK
Aug 20, 2026 6:51 AM UTC
Multibrand design system and inverse component variants
Hi there!
We have a large multibrand system with 17 brands which i’ve inherited.
Each brand has 2 primitive collections (standard + colours), and then the semantic collection which houses each brand as a mode.
There was no planning for inverse/knockout variants of components, so those needing an on-dark or a flexible background colour (and corresponding text colours) which of course we now need for some brands.
In the case of our footer, i had created knockout tokens to sit in the existing eg: font/colour/interactive/text button group and then created a new variant of the footer to map them too and added a boolean switch between the default and inverse themes.
But is there another way (without refactoring all of our tokens)
Jaycee Lewis
Jaycee LewisSolution
Aug 31, 2026 10:17 PM UTC
Hi ​@KatK 🤩 Hope your testing is going great! I don’t have a documented answer to naming conventions for variables. This one is your call.
You could:
  • Match the semantic names exactly
  • Prefix the new layer (them/text/primary) This keeps them distinct in the picker
Do you know what your designers prefer?
Talk soon! — Jaycee
Jaycee Lewis
Aug 20, 2026 5:01 PM UTC
Hey hey ​@KatK 👋 Great question! Inheriting a large multi-brand system is never a small thing.
I think your knockout tokens are in a good place, we just need to change how components consume them.
If i’m understanding your challenge, the main issue is: Each collection has its own mode axis, and axes stack. Yours has spent its one axis on brand, so inverse has nowhere to live. This is why you chose to use the boolean. But inverse is orthogonal to brand.
Have you considered giving Inverse its own collection?
  • Add a collection above semantic — Theme, or Surface — with two modes, Default and Inverse
  • Put only the tokens that actually flip in it (text, icon, border, interactive-on-surface)
  • Each one is an alias: Default → your normal token, Inverse → your existing knockout token
  • Rebind the components that need to invert so they consume Theme
  • Your 17 brand modes stay untouched
Context: objects are set to Auto by default and inherit their parent container's mode. So you set Inverse once on the footer frame and everything nested follows. To my eye, no boolean, no inverse variant, no threading a property through nested instances.
One question: is inversion always whole-surface (footer, hero, banner), or do you need inverse elements on default backgrounds in the same view? Whole-surface suits the mode cascade. Mixed genuinely wants explicit on-inverse tokens, in which case what you built is right and you'd just drop the boolean.
Talk soon! — Jaycee
KatK
KatKAuthor
Aug 21, 2026 11:01 AM UTC
Oh thank you SO much for answering!!
I was starting to play around with this idea, because some of our teasers will also need flexible bg colours, so was thinking of expanding the them modes in this seperate collection with brand, inverse, tertiary, secondary etc..
To the footer, the bg is controlled by 1 set token, so that doesnt need to flip, as well as decoration line (yet).. But the inversion should flip the text, text links, icons.
Best wishes
Kat
Jaycee Lewis
Aug 21, 2026 4:47 PM UTC
Hey ​@KatK 🤩 Thank YOU for asking a great question.  I think your instincts are right.
Two things to consider while it's cheap:
  • Put the background token in that collection too. It doesn't flip today, but keeping bg and on-bg together means picking a mode always gives you a matching pair
  • Add the decoration line now with the same value in every mode. Costs nothing, saves work later
One thought: inverse describes contrast, secondary and tertiary sound like emphasis. If every mode answers "what surface is this sitting on?", designers can pick correctly without a doc.
One note: the cost isn't tokens, it's contrast checking. Each new mode is more validation across 17 brands
Have an amazing weekend! — Jaycee
KatK
KatKAuthor
Aug 31, 2026 12:13 PM UTC
​@Jaycee Lewis Hi again :D
I was just wondering also about naming conventions for the alias tokens that sit on this new level. Should they be the same as the naming on semantic level?
Best wishes
Kat
Jaycee Lewis
You could:
Talk soon! — Jaycee
KatK
KatKAuthor
Sep 1, 2026 10:36 AM UTC
hi again :D It’s not broken yet 😂
I am a team of one :D - i will ask the FE Dev when he’s back if he has any preferences, but i was going with matching the names exactly. Im already seeing more things that need to be refactored 🤣
Best wishes,
Kat
