Ritche_Paz
Multi edit layer name
Is there a way that I can edit the name of a layer same name to be change at once?
Pavel_Kiselev
Power Member
May 24, 2024
Sure thing. You select layers, you press CMD+R / Ctrl +R and type new name in the dialog that pops out
Ritche_Paz
The problem with this method is that it will also change the same layer name from other screen. it is possible to multi edit within a layer or sublayer of the same name of that layer especially in tables.
