Multi-edit in nested frames
  • March 15, 2024
  • 281 views
Multi-edit seems to work on elements that are inside first-level frames but not on nested ones. I normally have many frames inside frames and the case of having to edit things inside first-level frames is not that common. Am I missing something? 🤔
Gayani_S
Hey @Juan_Mir, thank you for reaching out!
I am unsure if this is an expected behaviour. Let me check in with the team and get back to you once I receive more information on this.
Appreciate your patience in the meantime!
Juan_MirAuthor
March 18, 2024
thanks! I appreciate it.
Gayani_S
@Juan_Mir I’ve an update: Multi-edit works on things in nested frames, but they have to be inside different top level frames.
In other words, if you have a deeply nested object inside of a frame representing a screen of a phone app, and you have lots of copies of that screen, you can multi-select those nested objects.
However, if those screens are all inside of a giant frame, then you won’t be able to multi-select them.
Please let me know if this clears your question, happy to help further!
