Taylor_Rubes
Jun 28, 2024 6:38 PM UTC
Moving component: Links now break
Hello!! For the past couple of weeks my team & I have noticed the Figma updates changed and it seems like we can no longer cut/paste components AND retain the link, it makes you restore the component every time. So currently if I move a parent component that’s in 150 places, I have to manually update 150 spots. Anyone else? Should I open a ticket?
Gayani_S
Jul 2, 2024 1:33 PM UTC
Hey @Taylor_Rubes, thank you for reaching out!
Is it happening in the browser, desktop app or both?
Can you try clearing out the cache? Also please try to force-quit and open Figma in a new browser window (or force-quit the Figma Desktop app and restart it.)
If this does not resolve your issue, are you able to share a screen recording with me, so I can ask internally for help. We use these videos to try and reproduce the issue in our own files and so showing all steps needed to reproduce the behavior is helpful.
Taylor_Rubes
Jul 2, 2024 2:29 PM UTC
Hey @Gayani_S thanks so much for getting back to me! It’s not a machine issue and is happening to several teammates on different machines - here’s a bunch more context in the recording, let me know if I can send anything else your way to help!
Gayani_S
Jul 10, 2024 5:00 PM UTC
Hey @Taylor_Rubes, apologies for the delayed response! Thank you for the screen recording this is very helpful, let me reach out to the team internally. I’ll get back to you as soon as I get more information.
I appreciate your patience in the meantime!
Taylor_Rubes
Jul 17, 2024 7:19 PM UTC
Thanks @Gayani_S ! I have our Figma wizard also trying it on our side, let me ask her to Vimeo record so I can also send that your way in case it helps!
Taylor_Rubes
Jul 18, 2024 4:54 PM UTC
@Gayani_S video from teammate having same issue – Troubleshooting Command X Process 🛠️ | Loom
Taylor_Rubes
Gayani_S
Jul 19, 2024 11:00 AM UTC
Hey @Taylor_Rubes, apologies for the delayed response! Thank you for sharing the screen recordings with me.
I’ve got the following information from the Team:
This does not sound expected BUT there are two things that can cause it:
  • The component is unpublished / not up to date because:
  • There are conflicts on the component set (indicated by a warning or (!) icons on any component props in the Properties panel)
  • It has unpublished updates or is not set to public.
  • The file you’re pasting into includes instances of that component (this seems to have some additional nuance, maybe that there’s an instance that needs updates, but I’m still confirming those details).
If you’re seeing it any time you move a component, even a new component which has been published, then this would likely indicate a bug. Please do let me know if this is your case, I can submit a support ticket on your behalf and share your screen recording with the support team.
Gayani
Taylor_Rubes
Jul 19, 2024 4:38 PM UTC
Hey @Gayani_S,
I’m going to take this back to my team, test it out, and we’ll be back with a reporting! Thanks so much!
Taylor_Rubes
Jul 19, 2024 4:57 PM UTC
Hey @Gayani_S, this only accounts for “libraries”, aka a published file that’s connected to other files. Does that mean that support was dropped for moving without breaking in unpubished files that never get published? This seems to still be impacting our team when it comes to moving local components.
Noting this WAS possible before the Figma June updates.
Tom_Lowry
Jul 19, 2024 9:22 PM UTC
Hey @Taylor_Rubes, let me know if this video is helpful. There are a few steps to publishing and accepting library updates that are required to successfully move a main component from one file to another.
There has never been support for moving unpublished components. The closest thing I could think of is if you are pasting instances from the same file into a different one. Those will still have a reference to the main component without publishing, but will not receive any updates from the main component.
