Robert_Norgren1
May 11, 2022 12:04 PM UTC
Move comments to different page
Hi there,
during a project I often reorganize pages and frames.
Is there a way to move a comment to a different page? Or to have it follow along as I cut and paste that screen to a different page?
Thanks
Th_m_Phung_PT
Aug 9, 2024 10:28 AM UTC
Wao, thank you very much! 🤗
Lauren_Shupp3
Aug 9, 2024 4:17 PM UTC
I too would like to be able to move pages with comments to another file. My use case is pretty basic. Ideations occur within a file and eventually I realize I want to split them up in some new way that wasn’t obvious before. It turns out I was all over the place at first, but can organize one file for this part of the UI and one for the other, set it aside and use this new organization to focus and pickup where I left off next time. But I don’t want to lose all the comments from earlier ideations just bc I’m reorganizing. This is ONE use case. Figma needs to make this flexible to support any unforeseen use cases. Keep comments with stuff I cut/paste, copy/paste, or move. Duplicate comments if you have to, to avoid loss of the thoughts in their context. This isn’t an area to be limiting users on just because you didn’t anticipate a use case around how we want to re-organize. This is an area to be very flexible and remove friction.
Jakob_Behrends
Aug 22, 2024 8:19 AM UTC
so much +1
also moving comments to a different file is very important. this is where the “move to” hack does not work 😕
Hrag_Chanchanian
Aug 23, 2024 3:23 PM UTC
Another +1 for this.
Some design files with a lot of assets tend to break Figma, so we create archives etc. It would be super useful if comments transferred over to other files.
Arthur_Baracand
Oct 15, 2024 4:56 AM UTC
+1, so annoying, the “move to page” feature is not great cause we do not chose where in the page it will be moved, the CMD + X is much better to paste the design where we want
Petr_Siroky
Nov 18, 2024 10:42 AM UTC
I really wish it was possible to just move the comments to another file. This is such an oversight.
Rebekka_Karrengarn1
Nov 26, 2024 5:32 PM UTC
same wish on our side. we need it as a feature. is there a feature-request somewhere?
alircxa
Jan 22, 2025 4:55 PM UTC
Yes, I’ve been having the exact same struggle. You cannot cut and paste the frame with the comment, since the comment will just detach from the frame and stay on that said page.
BUT you CAN select the frame (or multiple), right click, move to page and select the page it should be moved to. This will include those comments, that are attached to the frame!
Good luck! 😊
Thanks!
Steven11
Apr 4, 2025 8:35 PM UTC
Good luck! 😊
Unfortunately, the comments don’t move if you are pasting your frames + comments to a page in a design branch in the main file.  For example, we keep all of our in-progress items in a design branch, and then copy them for review into the main file. While reviewing the designs in the main file, we add comments in real time. However, we can’t then move those comments back into the design branch for the same file. I wish they were tied together somehow.
