May 13, 2023 9:04 AM UTC
Mouse enter/leave flickering
Sorry I don’t really know how to explain this. I have a menu, while hovering with the mouse you should have a more options on each category. I made a classic mouse enter = open overlay / mouse leaves = close overlay, but in the preview, it keeps flickering when approaching the button area, like one pixel tells mouse enter and the next pixel triggers the mouse leave event, next pixel triggers mouse enter, etc.
Please take a very quick look and tell me if it’s a bug or if I made a mistake, thank you.
flickering mouse enter / mouse leave project
djvSolution
May 15, 2023 5:07 PM UTC
Sorry to hear this is happening, @Ioan_G_TyraelThas!
Please reach out to the support team directly via this form for help: https://help.figma.com/hc/en-us/requests/new
Please use your Figma account email, include a link to the file, and share it with support-share@figma.com, so they can take a closer look.
May 13, 2023 9:45 AM UTC
figma flickering issue
Here, I recorded it.
Roberts_Kaplans2
May 15, 2023 8:46 AM UTC
Same issue for prototyping complex navigation. Everything worked 3 month ago.
James_Wolfcale
May 15, 2023 4:12 PM UTC
Seeing the same thing. Worth noting that the flickering does not occur when you remove the mouse leave > close overlay interaction.
djvSolution
Tomas_Ernesto_Nones_Gonzalez
May 29, 2023 1:04 PM UTC
Also having the same issue.
I’m simulating the effect of a transparent header going sticky and changing to a solid bg color on scroll.
The way I did it was I made a copy of the home page with the sticky solid header. Then I used:
mouse leave on the hero section of home 1 → navigate to home 2
and
mouse enter on the hero section of home 2 → navigate to home 1
It worked as intended a week ago. Now it’s broken. Same flickering issue, once triggered it never stops. It loops infinitely between the two pages.
My only clue is that it started happening at the same time as the “state management” update.
Jun 5, 2023 5:40 AM UTC
Same issue here
Melissa_Wallis
Jun 12, 2023 5:09 PM UTC
Having the exact same issue, haven’t seen any solutions yet
Linda_Duong
Jun 15, 2023 5:41 PM UTC
I am also having the same issue.
The prototype flickers while prototyping a mouse enter = open overlay / mouse leaves = close overlay. It doesn’t flicker when you remove the mouse leave = close overlay interaction.
Jun 15, 2023 7:41 PM UTC
Here is the staff answer
Hi there,
I checked your overlay. “Mouse Leave” triggers whenever the mouse is outside a section, ‌not if the mouse enters and then leaves an area. Therefore, your overlay is both closing and opening at the same time, this is what is causing the flickering. To make this work properly, I would recommend using interactive components instead of the Overlay feature. An example of what I’m talking about is in the community file below.
https://www.figma.com/community/file/1101844796311678876
Still not sure why I should use interactive components instead of using mouse enter/mouse leave but well… I’ll try to figure out one of those days
Van_Wang
Jun 28, 2023 12:22 AM UTC
This explanation is misleading. There seems to be a bug associated with the “Mouse leave” functionality. Even in the example they provided, the solution involves a workaround utilizing “Mouse enter” alongside transparent boxes surrounding the dropdown menu to accomplish the intended purpose of “Mouse leave.”
