Mohammed_El_Effe
March 8, 2023
Mixing 4 frames in 1 responsive frame
  • March 8, 2023
  • 471 views
Hello All,
I created 4 same designs but with different frame sizes, each frame size is perfectly responsive. is there any way to mix these 4 together, for example when i resize the mixed frame, the layout automatically get responsive.
to sum it up, when i need to handle the frame for the designer, i want to give him only one frame not the 4.
Is there any way to help me do that?
Thanks
Pavel_Kiselev
Power Member
March 8, 2023
You can turn your four into a single component set so it will appear as a single thing where you can flip between break points by changing properties on it. And there are few plug-ins that does that automatically.
June 23, 2024
Which plugin please?
