kristiinave
Material Theme Builder - remove colours from the library
Recently I wanted to try out the Figma Material Theme Builder plugin but after a short test run decided not to use it. However it created into the colour library a bunch of default colours under the group “Schemes” that I can’t get rid of. I’ve uninstalled the plugin and manually removed from the right design panel the colours, but they still come up in the library. I haven’t used the colours anywhere.
Anybody knows how to get rid of these colours?
The Wandering Goat
**solved**
If you go to the `variables` panel you can delete the ‘Schemes’ variable group and/or delete the whole ‘Materials’ variables
