Sayali_Potdar
Sep 24, 2024 1:40 PM UTC
Main Component Changes Not Reflecting in Instances Across Files
Is anyone else facing an issue where changes made to a main component in one file are not reflected in its instance when copied to another file? Even after selecting “Reset all changes” in the instance, the updates to the main component don’t seem to apply.
Would appreciate any insights or solutions!
Oct 1, 2024 6:33 AM UTC
Hi there,
Thanks for reaching out! A troubleshooting step that may help regardless is a quick action called “regenerate all instances”. Can I have you try the following:
  1. Open your file
  2. Navigate to the search bar in the top left file menu drop down
  3. Search for “Regenerate All Instances”
  4. Run this command
If it doesn’t work, can you try “Repair component connections”?
I hope it helps , but if you still see the issue, could you reach out directly to the support team with a copy of your file: https://help.figma.com/hc/en-us/requests/new? Our support team will look into it.
Toku
