Alina14
May 22, 2024
Ломаются стили после обновления фигмы
  • May 22, 2024
  • 174 views
После обновления стиль с белым цветом стал черным, это распространилось на все проекты с данным стилем. Может быть кто-то сталкивался с подобным?
ksn
Hey @Alina14 - just to make sure I understand: you pushed an update to a style that somehow made an unintended change (white became black).
Are you able to try restoring a previous version of the file you have to see if that at least reverts all of the changes back to normal? Try that, and see if you’re able to successfully get the right changes to happen if you push out the changes you wanted again.
My apologies if there are translation issues on my end!
Alina14
Alina14Author
May 24, 2024
Hello! No, after the last update of Figma, the style with white color has broken: all elements where this style is used look not white, but black. Although the style uses #FFFFFF, when I split the style, the code takes on true meaning and becomes #232323.
ksn
So sorry for the delay @Alina14 – I did some tinkering on some styles on my end using white (#FFFFFF) as the color, but didn’t notice anything. However, this may be because the update caused the problem for your already existing styles, and I was trying new ones.
I think our Tech Quality team should look at this – can you fill out the following form and then let me know when you’ve done so? https://help.figma.com/hc/en-us/requests/new?ticket_form_id=360001744374
